Synth Demoing Variable StepLFO
Postby Duckett » Tue Feb 04, 2020 11:10 pm
Just a fun little noisemaker that demos a few uses for variable-step version of ye olde StepLFO... many and much thanks to Trog who rubbed the stupid out of my eyes with his reply!
I was dumb and didn't create the schematic in 3.06, but here's the VSTi
in 64-bit:https://www.dropbox.com/s/jz0l7z3el7kftpn/DuckSteps2%20%2864%29.dll?dl=0
and 32-bit: https://www.dropbox.com/s/wds9qfwrwwet6mo/DuckSteps2.dll?dl=0
EDIT: Attached 3.06-created .fsm, with added vertical steps selector :)
VariableStepLFO306version.fsm
(132.78 KiB) Downloaded 1216 times
Duckett
Re: Synth Demoing Variable StepLFO
Postby wlangfor@uoguelph.ca » Wed Feb 05, 2020 3:48 pm
Thanks Duckett; I'll check it out.
Took Me a while at first to get a sequencer running correctly off the hop; I guess this is the next generation of new problems :).
My youtube channel: DSPplug
Postby Duckett » Wed Feb 05, 2020 4:05 pm
Hey, thanks for checking it out!
I thought I'd included a "One-Key Groove" preset for those who just wanted to see how it works w/o digging in;
would you mind telling me specifically what wasn't working as expected/took so long?
If it's a question of aligning sync, something like Duck Steps is really meant more for quantized MIDI (unless you've got, like, 1/128-resolution precision playing live ;) )
Also, you probably found the inclusion of a nice big "Clear Audio" useful, I should've done due diligence w/ that...
In any case, the .fsm is posted now!
Duckett
Postby Halon » Sat May 16, 2020 7:13 pm
Thanks for this :D
Halon
