Working with data in a text file accessing by http:\\....
Hello ,
i'm trying to accessing data from a sensor.
The data file could be accessed to this address :
http://127.0.0.1:4444/bySerial/LIGHTMK2 ... Sensor.txt
Data are like this in the text file :
*** lightSensor
logicalName: ""
advertisedValue: "17.5"
unit: "lx"
currentValue: 17.6
lowestValue: 3.5
highestValue: 82.6
currentRawValue: 17.617
logFrequency: 1/s
reportFrequency: OFF
calibrationParam: 0,
resolution: 0.1
measureType: HUMAN_EYE
So i would like to make a module that can read this text file each minute then get the datas on line 6,7,8 line ( lowestValue
highestValue
currentRawValue )
How can i make this module in flowstone.
Thanks for your answers
François
*** lightSensor
logicalName: ""
unit: "lx"
currentValue: 17.6
lowestValue: 3.5
highestValue: 82.6
logFrequency: 1/s
resolution: 0.1
highestValue
currentRawValue )
François
- astroghost
Re: Working with data in a text file accessing by http:\\...
Can you give more information on what kind of hardware are you using?
- Tronic
So you have a file of sensor data on your local server, you could treat this as a normal file/folder & build a path to it, import the data into a string array, index 5,6 & 7 holds the required information, lucky for you there is a ':' delimiter, so you only require float data from index 5 after ':' delimiter.
All the information you require is in the user example subsection
Albert Einstein
Albert Einstein
JB_AU - Posts: 171
If you know a little bit how to work with php and Html then you can easily make a program that will read this text file after a giver time will update your database. All you need and ISR system, ISR 2.3.0 will work.
We are the best Shop front fitters in London. Contact us and give your customers a better first impression.
- frontfitters123
