Sidechaining audio sources internally
1 post
Somehow fixed my 3.0.6 version so I can finally share some stuff
This example shows how to internally sidechain a "slave" sound source to a "master" sound source, so whatever is connected to the slave source is ducked by the master source at the green range of the frequency spliter (which is actually the mid range). Of course, you can customize it and apply the effect to the low zone or the high zone or even to each zone separately quite easily.
Cheers!
Cheers!
(SIDECHAINING INTERNALLY 32BIT 306).fsm- Made with 3.0.6 version
- (106.43 KiB) Downloaded 1572 times
kortezzzz - Posts: 763
1 post
