The Quilcom Weapon
The Quilcom Weapon
Postby Spogg » Tue May 31, 2016 1:44 pm
Hello World :lol:
The Quilcom Weapon is one armament to have if you want to fight in the loudness war!
This is a one-knob compressor/limiter, with automatic gain make-up to simplify auditioning. It’s designed to control the overall “loudness” of a stereo signal by varying all the main compression parameters in step, to give a wide range of subjective loudness increase. It can also serve well on a microphone input for vocals or indeed any other source.
I’ve tuned the internal parameters using a wide range of tracks and inputs to give subjectively useful results over various types of source material.
Input and output metering, as well as bypass, are performed on the DAW to minimise CPU usage.
The input level for the compressor, from the DAW master channel or track insert, will interact with the Amount knob setting for additional range. In this way you could set the Weapon to max and control the effect from the DAW. This will give a different result to setting the Weapon to half way and increasing the drive from the DAW, so experimentation is the key.
There is a meter-scope to illustrate when and how much the compressor is affecting gain reduction. This is wired to the side chain output (control signal) before the make-up stage for better visualisation of the processing.
The exported VST is on http://www.flowstoners.com under Quilcom.
Quilcom Weapon 1.0.fsm
(816.84 KiB) Downloaded 1298 times
Re: The Quilcom Weapon
Postby ElCuco » Fri Nov 11, 2016 2:38 pm
I cant believe nobody make a comment.
AWESOME JOB!!!
ElCuco
Postby StereoSpace » Tue Nov 29, 2016 11:39 am
After the test, I noticed that in Fl studio is a delay after its inclusion in the chain. I added a delay compensation module and tried to draw a GUI.
You did not try to pick up an extra set ratio relations with the attack?
To be able to choose from three or four options, because the maximum value very much starts to bulge "tail" in the audio signal. for example in the notorious sound goodizer))
Thanks
fsm here https://yadi.sk/d/6-xCqOyKzjrTk
weapon gui.PNG (191.65 KiB) Viewed 21247 times
GUI designer
StereoSpace
Postby Spogg » Tue Nov 29, 2016 5:12 pm
Hi StereoSpace
That's a really nice looking GUI you've created; brilliant!
You've made a really good point about the audio delay for the look-ahead function. When I was tuning this I'm afraid I didn't do it within a DAW so I was just listening to various sources to get the best compromise settings, mainly for various final mixes.
The design for this was just intended to make stuff sound louder without the usual knobs and controls so I think a fixed Delay Compensation would be useful.
Thanks for this.
Postby StereoSpace » Wed Nov 30, 2016 1:47 am
Thank you! You are always interesting projects. If I have more free time, I'll design for other schemes)
GUI designer
StereoSpace
Postby BobF » Wed Nov 30, 2016 3:49 pm
Hello Spogg,
I have NOT used compressors much because I have always found them hard to use. Thanks for this one Spogg, I really like the how easy it is to use. Great work, I will definitely start using this one right away.
Cheers, BobF.....
BobF
