Red,White & Blues on the Greener Side ...
1 post
All newbies are completely stumped by FS (FlowStone formerly Synthmaker) color coding and program operations.
Red -
Project usually starts what with the red 'M" stuff for MIDI Inputs/Outputs prims and mods ...
These then proceed to hookup through page 'webwiring' to a ...
White -
Poly itsa-my-intern' iton-connects that interface between the digital coded MIDi Red, and after the White ... an actual Analog Audio ...
wOOoohW I maded a sound came outta my =Puter+ Speakers ... I AM AN IT'S ALIVENSTEIN!
Blue -
Audio that you can actually hear, real sound waves 'Virtual Sound Technology' (VST) based mods.
The controls that allow variation of project device features (volume, attack, decay, sustain, release, delay, etc.) are hooked into the mods with ...
Green
These are usually prims (primitives) that perform mathematical functions such as 'Bools' ... Boolean Algebra ... which what is simply ... true ... or ... false ... or combinations of these like on/off button sequences on your super-high-tech pac-man star-trek-warnage cellphones ... in the basket now ... stuff. duh.
Also 'Floats' (floating decimal point values like in mmm ... Pi = approx. 22/7 guestimento 3.14 ) and 'Ints' (Integers ... uhhh. ... okay ... whole numbers like err maybe "-1" ... orrrr .... 123,456,789,000.000.000.000.000) ... pheww I think I just counted all the holes in the ceiling cardboards &&&!
So you think it makes you sound like a Kool JunkYard Kat? Huh Jon-your-Knees boy! It sure looks like one $$$
LIke ... using only 'text visual aid' method /
FROM EXTERNAL DEVICE ... LIKE A 'LECTRIC-PIANO' PLUGGED INTO PC USB
<----- [ MIDI Input]
GREEN CONTROLS
[MIDI Output] ----->
{color=WHITE}----- [{(Poly 'as in multifunction transform')}] -----
MORE GREENERY CONTROLS
-----> [DSP 'blue-stompbox stuff' that can actually process audio] ---->
... TO SPEAKER OUTPUT
Red -
White -
Blue -
Green
GREEN CONTROLS
https://www.invntefx.com/ssl/_invntefxf ... fstone.htm
Inventor eFX Technology
LOGIN
Username: viewer
Password: A#1viewer
LOGIN
Username: viewer
Password: A#1viewer
pwesynthmaker - Posts: 71
1 post
Users browsing this forum: Google [Bot] and 44 guests
