Weird sound generator
Hello Gang,
It's been said I upload some weird stuff a good portion of the time, well this one I even call weird. I don't know if it even really has a use except for maybe a weird sound generator. If anyone wants to find a good use, please let me know. Also if anyone would like to add to it, just for fun of course. One example would be, on some delay settings the thing will finally start to sound more like noise than anything else, so maybe an auto-reset when it gets there.
Anyway, have fun and let me know what you think!
Later then, BobF.....
- BobF
Re: Weird sound generator
Very weird indeed, as would be expected!
I found it easy to create strange machine-type noises and also some great wind-like sounds.
I would say it needs presets next…
Thanks for sharing!
Thanks for sharing!
Hey,
So It's an LFO used as an OSC, with some kind of distortion as it is fed back to itself thru a delay unit, creating some kind of ring effect?
I've added a M2F with threshold to reset the audio... just for keepin my ears a few years more
Not accurate... at all... resets whenever it wants
Also an After-load trigger...
Could be quite cool if developed into a full Drone machine
Take care
Take care
tektoog - Posts: 141
I modified it for you so it can be exported as VST so you can now load it in FL Studio.
The midi wire is not connected yet but you can multiply it with the tone generator signal if you wish.
I also made changes to the UI because it was a complete mess.
BobsWeirdToneGenRobotronVst.fsm- (2.05 MiB) Downloaded 1151 times
BobsWeirdVstToneGen.fsm- Version 0000
- (1.87 MiB) Downloaded 1124 times
Download plugins here:
https://mega.nz/folder/nhVCkQRA#UWgU06K1o9gRFI0WqnBw_w
- DSP-Robotron
