Multiple Midi to Poly
Postby az-terisk » Tue Aug 18, 2020 10:03 pm
Hi Gang,
How can i integrate a multiple Midi to Poly instences, for project uses multiples sound sources ? I've found an example in my SM Archive, but after many tries, the conclusion is this : i can't integrate it in my project, it don't works.
Can you help me to start on this way ?
Thanks !
az-terisk
Re: Multiple Midi to Poly
Postby DSP-Robotron » Tue Aug 18, 2020 11:50 pm
Well, you better include some example file (.fsm) so at least we don't have to start from scratch. I need something similar that outputs to multiple midi ports. For creating wave sequences i have to find a way to output each note from the Arpeggiator to a different midi channel or to a different midi port.
DSP-Robotron
