A button with an editable name (string)
In my last project I needed a button which it's name on it can be easily edited by the user and saved as a preset. Sounds as an easy task for an experienced Flowstoner, but took me a while to build it quite solidly functional. Anyway, can be very useful for beginners, so here it is.
(editable label button 28_8_20).fsm- Made with ver. 3.0.6
- (9.6 KiB) Downloaded 1191 times
kortezzzz - Posts: 763
Re: A button with an editable name (string)
For a green-only solution this is very clean. Good work!
Hey Kortezzzz..i prefer your previous avatar...it was like a portal to another dimension..
Thanks for the feedback, tula. Seems like green would always be my one and the only option to make new thing, unless you guys are around...
billv,
Yep, those boring avatars is probably what happens when you're getting old
billv,
