Trigger LED
Trigger LED
Postby tulamide » Tue Mar 30, 2021 2:21 pm
Sometimes it's the small things in life. You probably know the little indicators that light up when the boolean input is true? I needed an indicator that lights up when a trigger arrives, and then shuts off after some time automatically.
You can set the time range, on and off colors in the properties.
Cheers!
trigger_indicator.fsm
initial version
(1.06 KiB) Downloaded 1209 times
Re: Trigger LED
Postby Spogg » Tue Mar 30, 2021 2:40 pm
Very nice!
Re: Trigger LED
Postby RJHollins » Tue Mar 30, 2021 5:27 pm
Interesting to see this in RUBY code. Thanks
8-)
Re: Trigger LED
Postby Halon » Wed Mar 31, 2021 5:19 pm
Thank you :)
Halon
