Convert String with Different Range Types to Array or String
Postby tiffy » Tue May 18, 2021 12:18 pm
Ruby - Convert a String of Values also Containing 2 or More Different Range Types ("-" and "..") to a Sorted Array or String Containing Only Values.
The Schematic should not display an error if any or all of the Ranges or Range Types ("-" and "..") are not present in the Input String.
Flowstone v3.0.6 Pebble.
Convert String with Different Range Types to Array or String.FSM
Flowstone v3.0.6
(990 Bytes) Downloaded 1035 times
tiffy
Re: Convert String with Different Range Types to Array or St
Postby RJHollins » Tue May 18, 2021 6:04 pm
Thanks TIFFY !
Always appreciate the 'specialty' modules you post.
Works great ... Toolbox entry 8-)
Postby kortezzzz » Wed May 19, 2021 11:33 pm
Great little gadget! thanks :)
kortezzzz
