Key Pads for Touchscreens
Postby Pali64 » Fri Jul 21, 2017 9:19 am
Hello all,
More 2 useful Tools i wil share with you :)
One Alpha and one Numeric KeyPad for string and Num entries.
its good for use as Filename or Numentry in Touchapp for Synthesizer or other FlowStone App's
Is Contrlable Window for automatic Hiden by Selectpin
Is Witen by "FlowStone 3.0.8" and Testet with 3.09
Happy to Use :D
Greeting Pali64
AlphaKeyPad.fsm
"FlowStone 3.0.8" Alpha TouchPad(Capital Letter)
(156.67 KiB) Downloaded 1504 times
NumKeyPad.fsm
"FlowStone 3.0.8" Numeric TouchPad
(52.87 KiB) Downloaded 1487 times
We made Keyboard and Synthesizer for you
so all Poaple can kommunicate with a Language to all poaple understand
Music is the nicest work in World ;)
Pali64
Re: Key Pads for Touchscreens
Postby Spogg » Fri Jul 21, 2017 10:36 am
Very clever! :ugeek:
I like that I can go inside and configure the keys with whatever character I want.
Thanks for sharing!
Postby Markk786 » Thu Aug 03, 2017 2:18 pm
Markk786
Postby Pali64 » Tue Jul 31, 2018 10:04 am
Hello all,
a Modifyred useful Tools i wil share with you :)
The Alpha-KeyPad for string entries.
its good for use as Filename or Touchapp for Synthesizer or other FlowStone App's
Is contrlable Window for automatic Hiden by Selectpin or as an Standalone EXE File with self-ending-Futures after te [ENT] Key was pressed or the Srver ist Terminateed.
New Futures:
1) The Keyboard can Kommunicate as anClient over Network (Use the Servermodule in you Applikation.
This is idealy to use as an Standalone EXE Program what Startet from your own software over the EXE plug-in
from Flowstone
2) Al keys are Konfigurable over the Property Window
3) The Keyboard has a Caps and Capslock funktion for free settable different keys
The Caps made selv reset after a Key is Pressed the Capslock holds until you press the [capslock] again or one of the two [SHIFT] key's
The kys has in this Variante Commands wich kan controlled it:
Send over the Server an "{TXT}........" command to place the Entryselect String on Leftside to Display.
Send over the Server an "{STR}........" command to place the Devault_Entry-String on Entrywindow.
Send over the Server an "{KEY}........" command to use as an Future Insigt on the Key-App
Send over the Server an "{PWR}1" command to ending the Key-App from your Applikation
After the Keyapp was Startet it send you over the Serverapp the String "{Mix}1" to tell you the app was Started and Online
Happy to Use :D
Greeting Pali64
AlphaKey_V0_2.fsm
(309.83 KiB) Downloaded 1306 times
Pali64
Postby wlangfor@uoguelph.ca » Wed Oct 17, 2018 2:11 pm
I made a post regarding making a universal system and rule for knobs and sliders. That would mean ideally that there would be a port of Your
schematic for touch screen support (with attribution); Is that OK?
LINK: http://flowstone.co.uk/support/viewtopic.php?f=4&t=13565&....
I figured it'd be great if We had a system like Voxengo, Waves worked out with available schematics to make it an easy thing.
My youtube channel: DSPplug
Postby wlangfor@uoguelph.ca » Thu Oct 18, 2018 1:48 pm
I came up with a new version that is the prequel to standardized slider/knob controls with touchscreen and tooltip / help window support.
Let Me know if this is acceptable Use and please let Me know if My using Your example to this end is OK; and I'll make the rest :D
The attachment new numberpad version.jpg is no longer available
And here is the schematic:
numkeypad v9.fsm
Requires Flow Stone beta 2.0.9 v2
(19.85 KiB) Downloaded 1246 times
Postby wlangfor@uoguelph.ca » Thu Oct 18, 2018 3:27 pm
BTW Pali, how do I make square links to modules? Can You tell me how?
Postby wlangfor@uoguelph.ca » Fri Oct 19, 2018 1:47 pm
Hi Pali, I made a new version which adds machine logic and adds numbers only within a range.
http://flowstone.co.uk/support/viewtopic.php?f=3&t=13634&sid=5ad79d6613ef7ea41b3724ae841e7285
