Vector knobs with embed randomizer unit
Postby Ricciardo » Sat Aug 28, 2021 6:43 pm
This is something i have had for a while but it would be selfish to not share...
I made this knobs using ruby, with embed randomizer.
So basically, you can make an entire synth with this and assign random to specific module areas to change parameters with a trigger.
All you have to do is to rename the wireless of the trigger combined with the receiver that is inside
the preset module of each knob
This knobs are super efficient, only 90 components, they will make any plugin not only load fast, as well as taking less memory hit due to not having bitmaps.
cheers
Knobs with random.fsm
(5.28 KiB) Downloaded 913 times
Ricciardo
Re: Vector knobs with embed randomizer unit
Postby Ricciardo » Wed Sep 01, 2021 3:38 pm
Actually ignore the post above...
the preset module had a mistake in the name routing...
(now fixed in the v2)
Knobs with random FIX v2.fsm
(6.06 KiB) Downloaded 915 times
Ricciardo
