Greysynth 2
Greysynth 2
Postby billv » Thu Sep 16, 2021 10:16 am
Greetings :) The original idea for Greysynth, was to route the modulators straight into the knobs,
so I thought I give it a go. Have fun :D
(Note: New version is available further down)
Grey Synth_Opt.fsm
(2.8 MiB) Downloaded 1280 times
billv
Re: Greysynth 2
Postby Halon » Fri Sep 17, 2021 7:57 pm
This is cool, thank you :D
Halon
Re: Greysynth 2
Postby Spogg » Sat Sep 18, 2021 1:15 pm
This is remarkable! :o
I see it’s at version 0.1 so I can’t wait to see it grow. At the moment I would need a user guide to check everything out, but the modulation aspect looks very impressive indeed.
Well done and thank you for sharing your work.
Re: Greysynth 2
Postby Neptune » Sat Sep 18, 2021 9:24 pm
Very nice. Thanks!
Neptune
Re: Greysynth 2
Postby billv » Sun Sep 19, 2021 9:25 pm
Thanks Guys.. :) I appreciate your feedback
Here's the next version..I think it's finished now...
New One note Drone Seq (Didgeridoo Simulator :D )
New sample Mod
New wave osc
New amp envelope (so now there's two)
New Gate (Mod 8 was removed)
New matrix triggers, Sample,Wave, Amp,Gate
New Flanger,Reverb ,Chorus
Grey Synth_Opt_2.fsm
(4.15 MiB) Downloaded 1230 times
billv
Re: Greysynth 2
Postby DSAED » Mon Oct 11, 2021 4:26 am
billv wrote:Thanks Guys.. :) I appreciate your feedback
New sample Mod
New wave osc
Can you explain a bit how it works ? Is this FM or what kind of synth is it ? I tried to extend the total number of presets to 256 but everything went out of control. All the knobs were moving on their own with no way to reset it. And it really needs a better user interface. This UI would not work in 4K.
DSAED
Re: Greysynth 2
Postby billv » Mon Oct 11, 2021 9:52 am
It works by focusing on Control Systems, Sequencing and Automation.
The syth itself is very basic- just 2 wav osc's and noise osc----filter--env--fx.
The only strange thing is your piano/kbd controller is not used. the sequencer does that.
The trigger matrix is when all the fun happens, where you can turn things on or off
via automation across the timeline. The modulators are routed directly into the knobs.
It should have a tutorial...and a better general explanation..please forgive my laziness :oops:
billv
Re: Greysynth 2
Postby Duckett » Tue Oct 12, 2021 7:37 pm
My stuff tends to want to incorporate lots of features- but I too suffer from documentation/GUI fatigue by the eventual time everything's sounding the way I'd actually like it to sound ;) ...
Duckett
