The Quilcom SIM-ALPHORN
Tulamide suggested I do an Alphorn, knowing I wouldn’t buy one because they’re about 4 metres long, very loud close up and expensive! So I had a look into it and became interested in having a go anyway, so here is the result:
https://www.dropbox.com/s/ayhp31eh953q0 ... 3.zip?dl=0
The download also contains the “ALPS” effect as a separate plugin, SIM-ALPS, which aims to suggest echoes, reverberation and diffusion you might hear in a mountainous region. Or you might not!
Here’s the video:
https://youtu.be/6DVgVFLWqEY
Now go get those sheep in!
Here’s the video:
Re: The Quilcom SIM-ALPHORN
Beautiful !) I feel like in a mountain
Just seeing something strange in the reverb modules.
You have the "4xAllpass" that get four frequency input.
But the code output is in mono using only one frequency.
Thanks to share so much very interesting !)
- Tepeix
And as always you didn't disappoint. It was just a bit confusing in the intro, because I'm not used to hear an Alphorn dry. But I think you nailed the characteristics.
Fun fact: the largest one piece Alphorn is over 10m in size and the largest multiple pieces Alphorn 47m!
hmmm ....
I just heard the RICOLA commercial
is it a full moon ?
is it a full moon ?
Thanks guys!
The reverb modules are by Martin Vicanek so maybe he can respond. I’m just a user
He’s made a better reverb since he did this, but I chose these ones because they use a bit less CPU and there are 5 of them!
Tepeix wrote:Just seeing something strange in the reverb modules.
Great work Spogg..cheers
