Audio Source Selector
Postby rocknrollkat » Sat Nov 25, 2017 1:18 pm
Hi Gang,
Here's an update to my "Simple Source Selector, now you can use it to select audio sources.
It's mono, so you'll need two for stereo.
You can add as many sources as you want, just remember that the rotary switch has to have
the correct number of 'min - max' numbers and detents.
The example shows "0 to 2" (3 in all) and 3 detents (steps) or the selector will not work correctly.
See the screenshot below.
And as always, it's a Dead Simple schematic, and I hope it comes in handy !
Enjoy !
ROXY :D
ROXY Audio Source Selector.fsm
(120.26 KiB) Downloaded 1559 times
rocknrollkat
