Phidgets Encoder High Speed 1057
Postby admin » Thu Nov 17, 2011 12:30 am
In this example we show how to interface to the Phidgets Encoder. Usually the encoder will be a quadrature shaft encoder with so many 'ticks' per revolution. The Phidgets Encoder counts these ticks and also measures the time between them therefore it is possible to determine not only a precise shaft position but and it's speed in RPM.
Phidgets Encoder clip.png (62.82 KiB) Viewed 46948 times
You can buy the Phidgets boards from http://www.phidgets.com
Phidgets Encoder.fsm
(9.94 KiB) Downloaded 3811 times
admin
Site Admin
Return to Phidgets
