OverSampling
OverSampling
Hey guys have a look at the 6th post down from this page:
http://synthmaker.co.uk/forum/viewtopic.php?f=4&t=5971&st=0&sk=t&sd=a&hilit=oversampling+toolkit&start=30
Its bootsy's comment and attachment. He says
Now if you look at his example, you see the packers & unpackers criss-crossing their 'flow lines' . . . WHY?
Whats the purpose, why not have the first 2 channels of the unpack match up with the first two of the pack?
Anyone have a clue why, or does it not really matter. . ?
I've attached an example on how to use straight forward SSE packageing on the 4x Polyphase Upsampler when using two channels
- Drnkhobo
Re: OverSampling
of you follow the packing closely, you can see, that it sorts the samples that channel 1 contains sample1, channel 2 contains next and so on...
Re: OverSampling
Thanks KG, why the need to sort the samples though?
Why do you need to pack the first 2 mono streams into a 'packed' stream, then up sample, then unpack them to pack AGAIN. . ?
thanks for the feedback !
- Drnkhobo
Re: OverSampling
It is merely a cosmetic thing. it is easier to write oversampled algorithm when you know the samples go in in right order.
