Stream FFT and iFFT
Re: Stream FFT and iFFT
Cheers Tronic - that looks very useful.
I had a go at the code. After I descrambled it
I just replaced the inner loop with a real SSE. It basically calculates the real and the imaginary part simultanously. This reduced the CPU usage down to 1/3 !!!
I guess this can be improved a lot more. Especially the bit reordering part can get reduced. As it is a fixed FFT, you could save the reordering pattern in stage 0 into an array and when a sample comes in, you put it to the right spot using this array.
Stream FFT v001 Build 8 +MyCo.fsm- (157.23 KiB) Downloaded 1615 times
MyCo - Posts: 718
I've done a little bit more cleaning. The main FFT processing part is now ready for variable FFT sizes.
Stream FFT v2 (trogluddite, MyCo).fsm- (156.61 KiB) Downloaded 1577 times
MyCo - Posts: 718
Done!
This is now a flexible version, it has no hard code FFT Size anymore... although I haven't tested it yet. For absoulte flexibility, we have to move some code from stage0 into stage1, haven't done this yet.
I've also changed the bit reversal method. Instead of rearranging the buffer once, it does it every sample now. This doesn't make a huge difference on large audio buffer sizes. But when the buffer is smaller then the FFT size, this should give a performance boost.
I've removed the sine table creation stuff. Instead it uses the wavetable that FS already has. Saves a little bit memory... the performance isn't better.
Stream FFT v3 (trogluddite, MyCo).fsm- (153.76 KiB) Downloaded 1646 times
MyCo - Posts: 718
Wow, MyCo, you really hit the turbo fuel-injection there - even my little Atom netbook now runs it at sensible CPU loads!
Fantastic work, many thanks!
Would be cool to benchmark this code against pure C/C++ code. It's surely not the fastest code around, but I think it beats pure C/C++ versions.
MyCo - Posts: 718
v3 is around 2x slower than v2, is this correct? (looks like on my both C2D)
About 50% more for v2 on my systems - that tallies quite well with the results I got when I traded "one shot" for "continuous" bit-reversal, though that could just be a coincidence. A lot will depend on CPU cache size/performance, so results will likely vary quite a bit between systems. Still WAY faster than my original port, though!
great job guys.
is coming, a stable version of a MEMin and MEMout in ASM code.
finally found a way, without using any primitive hidden.
will post as soon as ready, I'm working on, testing it, to make it easily understandable and usable.
digitalwhitebyte - Posts: 106
trogluddite wrote:About 50% more for v2 on my systems - that tallies quite well with the results I got when I traded "one shot" for "continuous" bit-reversal, though that could just be a coincidence.
In v3 is the output connected to DirectSound, in v2 it is not. v3 is even without disconnection faster here. I have an my AMD, though.
MyCo - Posts: 718
