less then 10 samples delay in code??
Re: less then 10 samples delay in code??
Postby nix » Fri Feb 11, 2022 9:29 pm
awesome work to be shuffling asm like that!
nix
Postby Tepeix » Fri Feb 11, 2022 10:54 pm
Thanks ! This one is very simple, not using array or rndint.
I updated the file.
I forgot to mention that the mod input must be in -1 to 1 range or it will break feedback or raise the volume .(
For more depth an other code are needed or we have to use more unit in series.
Tepeix
Postby nix » Fri Feb 11, 2022 11:22 pm
here's the delay I wrote a long time ago, in quasi dsp==>
https://bit.ly/ECHOecho
yah- I can't write in assembly, just looking there to see what it(Assembly) can give me as modular devices
...sorta getting this vastly logical paradigm more
-and u have wiped the board with me mate heh
keep shufflin'!
nix
Postby Tepeix » Sat Feb 12, 2022 12:35 pm
Very cool delay !
I could not open it in flowstone because i'm on 3.6.
But i try it with LMMS and like it a lot !)
Tepeix
Postby Tepeix » Sat Feb 12, 2022 2:27 pm
I make another one that is more minimalist.
Hard for me to measure which one is faster for the same depht.
This one have only 2 samples delay and the mod mix only those 2 sample.
To get the same depth more of this one must be used in series.
But there's no more conditional line inside so maybe faster ?
Well, it's more a vibrato than a delay ;)
streamin in; streamout out;
streamin mod; float a1=0;
float a=0;
movaps xmm0,in;
movaps xmm1,a;
movaps a,xmm0;
movaps xmm2,a1;
movaps a1,xmm1;
//mix mod//
subps xmm1,xmm2;
mulps xmm1,mod;
addps xmm2,xmm1;
movaps out,xmm2;
I first get some problem with feedback at more than 0.5.
Then including a denormals in the loop it's gone... ?
The more the delay is short the more the feedback must be down ?
In the example we have 16 delay, so a total of 16-32 sample delay.
Also the quality is maybe better than the other that was skipping some sample when mixing the mod.
This time the mod input must be 0 to 1. Negative value give very bad and loud sound !
MinimalmodDelayv2.fsm
(43.83 KiB) Downloaded 689 times
Tepeix
Postby nix » Sun Feb 13, 2022 9:20 pm
would you like the 4 Alpha?
you're welcome to it if u have purchased
nice work
nix
Postby Tepeix » Mon Feb 14, 2022 12:20 pm
Thanks !
I don't know where to get the alpha but i just get recently Flowstone so i wait a little.
I was using Synthmaker before.
Now i try to see if my little delay make some sense to use.
I didn't find a way to precisely check the cpu.
I think for a very little vibrato it could be faster. But not when we need more depht.
There's something different from a normal vibrato, an interpolated delay
will only mix 2 sample but here we have a lot of sample mixed in series.
So when the Osc is in middle position (or in +0.5 -0.5 for the first one) the signal lost a lot of treble !
It's a sort of wha/vibrato ;)
I try to find a way to mix more sample but maybe it's better with an array.
Tepeix
