Denormals
Re: Denormals
Postby KG_is_back » Thu Sep 18, 2014 11:47 pm
tester wrote:Will/would such portion of code change something (CPU usage) in (where in the design where? input?) zdf filters posted somewhere here?
The CPU usage of the denormal remover are relatively small (one comaprison, two "and" operations one writing to value...around 7 cycles).
You should put it in the feedback of the algorithm. just in front of the link that loops backward.
Re: Denormals
Postby martinvicanek » Fri Sep 19, 2014 1:18 am
