triggerdelay in samples - Ruby?
Postby Nubeat7 » Sun Dec 09, 2012 8:48 pm
hallo,
i would need a triggerdelay where you can choose the time in samples, tried out some things but couldnt get it, someone of you has an idea where to start or how to do it, maybe modifying the ruby ticker ?
Re: triggerdelay in samples - Ruby?
Postby trogluddite » Mon Dec 10, 2012 3:42 am
Hi Nubeat,
This should do what you want...
Samples Delay.fsm
(1.11 KiB) Downloaded 1732 times
...couple of things to watch out for, depending how accurate you need it.
- Must be an ASIO/DS component running for accuracy; 100Hz clock is used when no audio running.
- Sending the output trigger through lots of green components will also make the timing a bit more 'slack'; keeping it all in Ruby/MIDI is more accurate.
Postby nix » Mon Dec 10, 2012 4:56 am
ooh!
Haven't tested, but thanks a bundle trog.
I bet I use this somewhere.
Much appreciated!
nix
Postby Nubeat7 » Mon Dec 10, 2012 8:37 pm
thanks, trog exactly what i was searching for! and a little step to understand ruby a little bit better :)
