Logarithmic Frequency Sweep
Some time ago I did a linear frequency sweep in Synthmaker. I'm attaching the FSM file.
I now have a necessity for a logarithmic frequency sweep instead. Does anyone have any ideas how this might be accomplished?
Linear Frequency Sweep.fsm- (1.61 KiB) Downloaded 1582 times
SBMastering - Posts: 17
Re: Logarithmic Frequency Sweep
A simple power function should get you a nice log sweep, for example...
freq = base_freq * (2 ^ time)
...would rise by one octave from the base_freq each time 'time'; increases by one. In Ruby, the power operator is '**' not '^', so it would be... freq = base_freq * (2 ** time)
I couldn't get the power operator to work in the regular code window with "^". It just turns everything into black text. I have looked all over. I'd hope to avoid doing it in Ruby because I haven't been working in Ruby much yet and this just needs this one little tweak!
I'm posting a screenshot of the sweep. Also, please check out my uploaded example on my previous post.
BTW, Trog, I am going to PM you about something unrelated.
use pow(e,n) for ^
- Tronic
Ok, I got it working with pow and increasing logarithmically. Now I'm working on trying to figure out how to get it to decrease logarithmically after it reaches it's highest point.
What makes the "movement" logarithmic - is the signal scaling itself, not direction you go. It works like this. If you rescale your values into (0-1) range, and apply lin to log transformation, then what will change is the curve between 0 and 1, but the range remains the same (then you may rescale it back into whatever you wish). By curve I mean corresponding y values to x values. In linear case y=x (or y=nx, depending on initial scaling). In other cases - all depends on what you used.
