3 stage mix module ?
Postby Wishx » Thu Feb 06, 2014 7:12 pm
Hi guys I had a wierd idea, wich seems quite hard to acomplish.
I'm talking about a three stage mix module . For starters
What I essentialy mean is for example: in a normal mix module we put a dry and wet and mix between them.
What if we had 3 channel inputs, and want to mix in betwen them like this: Image
I represent the knob in this picture so L1 is min value, M is 0.5 and max 1 is the R.
Can it be done ? Enlighten us, with your experience and Knowledge!
Thanks :D
Wishx
Re: 3 stage mix module ?
Postby KG_is_back » Thu Feb 06, 2014 8:07 pm
I am not quite sure what you what to archive. You what 3knobs in one that are ale scaled 0-1?
or do you what the sum of the three to always be 1?
Postby martinvicanek » Thu Feb 06, 2014 8:10 pm
Check out cyto's continuous blend schematic here:
http://synthmaker.co.uk/forum/viewtopic ... &sk=t&sd=a
Postby Perfect Human Interface » Thu Feb 06, 2014 8:16 pm
This should work.
3-Way XFade.fsm
(12.87 KiB) Downloaded 1514 times
Postby tester » Thu Feb 06, 2014 8:18 pm
You mean - you are looking for mid-side encoding/decoding plus standard stereo pan?
Postby Wishx » Thu Feb 06, 2014 10:15 pm
Hi guys thanks for the prompts reply, I want a mix knob (found in audio tools) that has instead of dry / wet input to utilize as mix, more inputs 3 actualy
Wishx
Postby Wishx » Thu Feb 06, 2014 11:42 pm
Perfect Human Interface wrote:This should work.
THis seems to be it, from some first test... im kinda wowed !? haha :o and all the articles and info are great guys ! thanks so much :D
Wishx
Postby Wishx » Thu Feb 06, 2014 11:44 pm
Yeap thats it, amazing guys... It makes me wonder can this be done with 5 inputs , or 10 :o ?
Wishx
Postby Perfect Human Interface » Fri Feb 07, 2014 3:02 am
The one posted above by Cyto apparently uses a more complex method that can use any number of inputs (just from glancing at the thread).
That one I just made isn't complicated even if it looks so. If you study it a bit I'm sure you can make sense of it by following the math. It's just modifying the way the knob value is applied to each of the three input levels. If you can understand how a typical crossfade works (a 0-1 range value multiplies one signal level while the difference, 1 subtract that value, multiplies the other) that should get you started.
And yes, there is a method to create this type of fade that works with N inputs.
Postby Wishx » Fri Feb 07, 2014 1:01 pm
Thanks, I'm trying to dive as deep as I can and understand what I come across :)
Wishx
