Suggestion for new extended code component
Postby KG_is_back » Sat Apr 12, 2014 1:17 am
Current DSP code component is optimized to work for sse 4channel streams. Some instructions that would cause problems in mono4 and poly signals are ruled out from DSP code, but are still available in assembler primitive. I think it would be reasonable to have a separate "extended" DSP code component that would be able to process only mono (maybe mono4) signals and would contain several new functions reganding code branching and looping.
This article is both an suggestion for DSPR and a tutorial for users how to implement the stuff in assembler until it's implemented in the code component directly.
First of all "If else" instruction... the syntax would look like this:
if(a,0) //a is a variable or conditional statement containing boolean mask
// 0-3 is an index of SSE channel to take the mask from
//code1
else
//code2
the assembly generated code would be
movaps xmm0,a; //in case of statement this would be the statement calculation
movaps smIntVarTemp,xmm0;
push eax;
mov eax,smIntVarTemp[0]; //0-3 from the parameter;
cmp eax,0;
jz else1;
//code1
jmp skipelse1; //jmp is not implemented, so following code might be used instead:
// mov eax,0;cmp eax,0;jz elsecode1;
else1:
//code2
skipelse1:
pop eax;
The if else branching can currently be replaced by flag based statements, but conditional loops can't...
Conditional loops would be implemented in similar fashion...
while loop
while (a,1)
//code
generated assembly:
push eax;
while1:
mov eax,smIntVarTemp[1]; //0-3 from the parameter;
cmp eax,0;
jz notwhile1;
//code
jmp while1; //jmp is not implemented, so following code might be used instead:
// mov eax,0;cmp eax,0;jz while1;
notwhile1:
pop eax;
other branching like do-while loops are possible too...(I'm just too lazy to write them down at the time :oops: )
