Voice Changer/Morphing
Postby maleche » Mon Jun 27, 2011 11:00 pm
Anyone had success in making a Real-Time Voice Changer Module? It appears that one is possible. I'm trying the FM modulator with various pitch and speed. Still having problems with microphone input. I can get a wav file to play but mic is not processing through.
Still working...
maleche
Re: Voice Changer/Morphing
Postby trogluddite » Sun Jul 24, 2011 11:45 am
There are many examples of these kind of audio-mangling over at the SynthMaker forum - most of the files there should work OK in FlowStone (just change the filter to 'All Files' in your load dialogue).
Here are a couple of examples that spring to mind...
Frequency Shifter
Pitch Shifter
If you're really into messing with audio, it will be well worth joining the SM forum - the software is essentially an 'Audio only' subset of FlowStone - but as it has been around a lot longer, there are so many more excellent examples, and loads of forum users who really know their audio processing chops.
