How do I make a poly from a float?
Postby boi123 » Sat Oct 26, 2019 12:49 pm
I want to experiment with alternative tunings, so I need to be able to make notes with exact pitch.
I can get a float from a poly, but not backwards.
ps I am new to ask questions online, don't hesitate to tell me if I am wrong
boi123
Re: How do I make a poly from a float?
Postby Spogg » Sun Oct 27, 2019 8:07 am
I’m not sure this will help, but if you connect a float to a poly stream input, the value of the float will offset any data in the stream and affect all poly channels (notes) equally.
So, you don’t need to somehow convert a float value to poly first!
Postby martinvicanek » Sun Oct 27, 2019 10:58 am
As Spogg explained, you can connect (green) floats directly to poly, and they will affect all voices in the same way. Sometimes, however, you want to use data derived from a (blue) stream in the poly section, for instance if you want to modulate a synth with your voice. In that case you may use a module from the early Synthmaker era (refer to the attachment).
MonoToPoly.fsm
(1.57 KiB) Downloaded 1362 times
