latency delay ping timer
Postby kinicho » Fri May 29, 2015 4:31 pm
this is my first post.. please be kind..
I am trying to build a latency delay ping timer akin to the one found in cubase and nuendo to measure the latency caused by the audio card.
I hacked a little timer but my guess is that ruby Time is not accurate enough
ideally i would like to send a dirac spike and get a delay value in samples
any help and hints would be greatly appreciated.
greets kinicho
_delay_ping_timer_001.fsm
(53.97 KiB) Downloaded 1464 times
kinicho
Re: latency delay ping timer
Postby MyCo » Fri May 29, 2015 5:12 pm
Since you need sample accurate measurements there is only really one option: Measure the time in stream. I've attached a sample schematic that does exactly that. It counts the samples between two stream events.
You can hook up the 2 inputs to the code module to your detector (eg. the envelope followers). But since the envelope follower output is a continous up/down counting value you have to implement a hysteris converter, something like if value greater x output 1, else output 0.
counter (MyCo).fsm
(1.76 KiB) Downloaded 1513 times
MyCo
Postby kinicho » Fri May 29, 2015 7:34 pm
Wow! Amazing - thank you very much. :D
this makes a lot of sense.. I should be able to finish this now -
kinicho
Postby kinicho » Mon Jun 01, 2015 1:50 pm
I had a go, but did not get very far.
the ping back works I can trigger the start and stop but i get varying results:
I then tried a trigger delay to see if it would give me the same result - but it doesn't
could you explain?
counter_MyCo_02.fsm
(2.13 KiB) Downloaded 1484 times
kinicho
Postby kinicho » Mon Jun 01, 2015 1:53 pm
here's what i got so far:
using exo's sample player
_delay_ping_timer_008.fsm
(106.73 KiB) Downloaded 1467 times
kinicho
Postby MyCo » Mon Jun 01, 2015 5:11 pm
You can't have any green stuff in the measurement path, because green is not realtime. You can only measure as low as one buffersize when you use green. I've attached an example of how to use the measurement in stream only. It uses just the envelope followers and a converter code, that changes it output when the envelope follower crosses a threshold level.
feedback measurement (MyCo).fsm
(136.28 KiB) Downloaded 1543 times
MyCo
Postby kinicho » Mon Jun 01, 2015 6:51 pm
Ah I see - thanks very much MyCo!
I need to get into the DSP code module by the looks..
now i also understand your last post.
kinicho
