Conditional selection
Postby juha_tp » Mon May 25, 2020 9:44 am
If one wants to stay with DSP code component, how to code conditional selection?
pseudo code:
switch value
case (1, 3, 5, 7)
otherwise // 2, 4, 6, 8
Any examples out there?
juha_tp
Re: Conditional selection
Postby adamszabo » Mon May 25, 2020 12:31 pm
I believe its only possible with assembler
adamszabo
Postby Spogg » Mon May 25, 2020 3:57 pm
Maybe this will help...
viewtopic.php?f=4&t=8731&hilit=bitmasking
Postby juha_tp » Tue May 26, 2020 7:23 am
Spogg wrote:Maybe this will help...
I did look that thread earlier but, could not find examples of usage since I need to make at least four operations (calculate coefficients using degree 3 polynomial equations) when the condition is true instead of just making one operation.
I guess "if" type statement could work if condition is checked for every coefficient calculation operation:
if(x % 2 != 0) a0 = polynomial
if(x % 2 != 0) a1 = ...
if(x % 2 != 0) b0 = ...
if(x % 2 != 0) b1 = ...
if(x % 2 == 0) a0 = ...
Could this be possible ... ?
juha_tp
Postby adamszabo » Tue May 26, 2020 11:47 am
That would use way too much cpu, since it still calculates all your equations even if they are not "enabled"
adamszabo
Postby tulamide » Wed May 27, 2020 12:09 am
First thing that came to my mind was cubic interpolation, but you wouldn't need any conditionals for that, and it seems to be code for a filter. Maybe if you elaborate on the topic? Maybe there is another way?
Simple example, if you're only interested in every second sample, you could use hop(2) and had no need for the conditionals anymore.
Postby wlangfor@uoguelph.ca » Wed May 27, 2020 8:41 pm
I'd love to know the answer to this as well.
My youtube channel: DSPplug
Postby juha_tp » Wed May 27, 2020 9:26 pm
What I'm trying to do is a LR crossfeed plug-in without Ruby code. I'm using polynomials to calculate coefficients (in attached example I'm using BLT based implementation).
There's also something wrong with the LPF filter.
EDIT: attached the schematic
Linkwitz-Riley Crossfeed_unfinished.fsm
(1.83 KiB) Downloaded 1508 times
juha_tp
Postby adamszabo » Thu May 28, 2020 9:04 am
Its best if you post a schematic because we have no idea which filter you are using that is different from the left or right channel, these graphs dont really tell us anything
adamszabo
Postby juha_tp » Thu May 28, 2020 10:12 am
OK, updated my previous post with schematic.
juha_tp
