EQ Biquads limitation, direct Forms and representation
Many EQ's and filters use 2p2z (two pole two zero) IIR filters, just like in Flowstone's stock modules.
With the FS implementation I do not see any limitation on the maximum/minimum values of the coefficients.
However, I know that some DSP manufacturers limit their coefficients to (example) +/- 2.0 . So a value of (-2.00001) is not possible. Claim is stability of the filter.
I wonder why is this limitation required in the DSP but not in FS. I tend to think that this limitation is required for "fixed point" presentation (say 20 or 24 bit) and not required for "very wide dynamic range" like in "32 bit floating point".
Also I know that "fixed point" representation uses "direct form 1" while "floating point" uses "direct form 2", as explained here https://www.earlevel.com/main/2003/02/28/biquads/.
But how is that related to coefficients limitation ?
- Rocko
Re: EQ Biquads limitation, direct Forms and representation
It may depend on the underlying hardware model. The only time I ever had to implement 2p2z in fixed-point, the most efficient way was direct form 2: the processor pipeline had two 16x16-bit multipliers feeding a three-input 32-point adder. (It was optimized for FFT butterflies.) And yes, it was twitchy if you wanted to minimize quantization noise, but at least there were also shifters at the adder inputs and output to help keep everything within limits.Rocko wrote:Also I know that "fixed point" representation uses "direct form 1" while "floating point" uses "direct form 2", as explained here https://www.earlevel.com/main/2003/02/28/biquads/.
Thankfully, I was not the poor bastard who had to determine the scaling values.
- deraudrl
Appreciated.
Can someone explain why in 'fixed point' one needs to limit the coefficients of the denominator?
While (I believe) that in floating point this is not needed?
- Rocko
Rocko wrote:Can someone explain why in 'fixed point' one needs to limit the coefficients of the denominator?
These may help:
https://dspguru.com/dsp/howtos/implement-iir-filters/
http://www.eas.uccs.edu/~mwickert/ece56 ... fp_IIR.pdf
(Or not.
- deraudrl
