Help to make Side chain plugin like Nicky Romero Kickstart
Help to make Side chain plugin like Nicky Romero Kickstart using Flowstone.
http://www.kickstart-plugin.com/
JC Conkato
rdgaudio - Posts: 32
Re: Help to make Side chain plugin like Nicky Romero Kicksta
Interesting!
Needs 4 inputs. Stereo to be processed and stereo source for the control channel (side chain). Mono selectable for inputs and outputs.
Then selectable and adjustable envelope follower(s) (rms/peak/attack/decay/method etc.) with output response envelope shaping, threshold, knee, amount and make-up levels.
Basically a compressor/limiter with sidechain input? Or something more simple?
I think its just a very simple volume curve thats multiplying the incoming signal, nothing fancy
- adamszabo
Indeed, the purpose of Kickstart was to give the EDM scene a tool to get the pumping effect (which EDM is living from) without cpu intensive compressing. You just put a repeating curve on the amplitude control that changes the incoming signal amplitude. That's it.
tulamide wrote: You just put a repeating curve on the amplitude control that changes the incoming signal amplitude. That's it.
But you must surely have some sort of envelope follower? That's where choices have to be made.
Spogg wrote:tulamide wrote: You just put a repeating curve on the amplitude control that changes the incoming signal amplitude. That's it.
I never understood what an envelope follower is and nobody ever explained it to me in a way I could understand. So maybe my answer is a bit off, but this Kickstart tool has no complicated dsp. It is linked to midi, so that's where it knows the cycle from, and it uses premade curves. A curve is a bunch of numbers basically, with each number an amplitude value in the full digital range 0-1, so on every tick within the cycle it applies that value to the volume out. Done.
Im sure its just a tempo synced lfo thats playing that curve on the graph
- adamszabo
tulamide wrote:I never understood what an envelope follower is and nobody ever explained it to me in a way I could understand.
An envelope follower converts the amplitude of an incoming sound to a control level, usually unipolar and typically in the range 0-1. This can then be used for anything that a control signal could be used for. For example controlling the output level (as in a compressor), or the filter cutoff frequency or a display on a meter.
The design details of the envelope follower will affect its response to the incoming signal. For example do you want to follow the rms value or the peak value and also how fast should it respond and how slowly the control signal should decay.
Plus, no fast envelope follower is immune to producing ripple on the control signal so a compromise may be needed for some applications to avoid distortion.
Hope that helps a bit.
Hahahaha...
Thank you Spogg Sir, Tulamide Sir and Adamszabo Sir. Adamszabo Sir's concept is matching with my thinking.
What I am asking for is a predefined volume curved that is synced. In FL Studio using Gross beat or Love filter we can make Side chain from scratch and it's completely user customizable. But the Nicky Romero Kick Start is just a preset of Volume curved or a kind of Tempo Synced LFO. Most importantly it consumes very low CPU as a VST Plugins.
So I guess it is not like the so called Compressor with SC input etc.
However,I understood the theory but my point is.............................................
How can I do it Practically in Flowstone?
Frankly, I don't understand Flowstone very well. Imagine I am your student and you all my sirs.
JC Conkato
Yes you are right, a compressor like tool OR envelope follower depends on the actual signal and follows its volume with different parameters line attack OR release... While the tool you are behind is just a synced envelope which isnt depending on the source signal itself, it also has nothing to do with sidechain modulation, because it doesnt feed any other soundsource into the Plugin which would manipulate the target signal, its basically a trancegate with different waveforms
