Simple DSP question re code execution with no output
Postby Spogg » Tue Apr 11, 2017 4:01 pm
Hi!
Simple DSP question: Is the whole of a DSP code block evaluated every sample even if some of the outputs aren’t connected?
For example, a state variable filter where only the high pass output is connected to anything.
Re: Simple DSP question re code execution with no output
Postby adamszabo » Tue Apr 11, 2017 5:32 pm
If you only have open output from the DSP code box then I believe its not calculated. If you have multiple output from it and even if you only connect one thing to it, the others will be calculated as well.
adamszabo
