Visualizing input stream
Postby jto1 » Sat Nov 24, 2012 12:57 am
Hi, I have a problem viewing audio coming from my mic. I've checked the asio settings and all is good.
I'm using the intergrated mic on my laptop. could someone tell me where i'm going wrong. here's a screen shot
thanks
https://skydrive.live.com/redir?resid=F ... phd5JpBfGM
jto1
Re: Visualizing input stream
Postby unkargherth » Sat Nov 24, 2012 2:52 am
Dont' know for sure, but i will put an ASIO out , making sure is active. Usually "Blue" flow only works when an audio output is active
Free your memory, .. with a free(). Like a pointer
Cast a pointer into an integer and it becomes the integer...
Cast a pointer into a struct and it becomes the struct...
A pointer can overflow... or can crash...
Be a pointer my friend
unkargherth
Postby jto1 » Sat Nov 24, 2012 11:57 am
Ok cheers, i'll give it go.
jto1
Postby jto1 » Sat Nov 24, 2012 12:00 pm
Brilliant! thanks unkargherth it works now
jto1
