Abstract Keywords in Robot Framework
Discuss robotics applications using FlowStone here
Postby sivaprasadpadhy » Mon Nov 26, 2018 7:00 am
is it possible to implement abstract keywords, so that you can avoid duplicated "code" and also avoid technical arguments in the actual test implementation? It's also very important to me, that the abstract Keyword is not usable in any actual test implementation.
What I want to have is something like that:
*** Abstract Keywords ***
Open Menu Item
    [Arguments]     ${menu}
    Click Element    ${menu}
*** Keywords ***
Open Home
    Open Menu Item    Home
Open Setup
    Open Menu Item    Setup
Does Robot Framework support abstraction?
sivaprasadpadhy
Return to Robotics
