LabJack U12 Support?
Discuss robotics applications using FlowStone here
Postby paul.pacini » Fri Jul 29, 2011 12:44 am
I have a LabJack U12 I used a while back for a robotics project. I programmed it with VisualBasic 6 and it worked pretty well. I see there are components for communicating with the LabJack U3 HV/LV and was wondering if anybody knew if the protocols were similar between the U3 and the U12? There are differences in the number of digital I/O's and analog inputs, but otherwise, I suspect their serial communication methods of loading variables with values and reading variables is probably similar.
Is there any way to disassemble the LabJack U3 component to see how the data-stream is handled? Has anyone done this and can give me some pointers?
Kind regards,
Paul
____________________________
To err is human; to blame problems on external factors is even more so.
paul.pacini
Return to Robotics
