Support for Phidgets 4-channel DAC?
Are there any plans to add the Phidgets 1002, USB to 4-channel analog output board to FlowStone?
There is so much support for the Phidgets devices in FlowStone, and understandably so considering their impressive line-up, that I thought this might be on the list too, or maybe soon will be. But, I don't see anything in the literature or on this forum supporting it.
Seems there must be a need to produce analog voltages for robot control. I have just such a need
Thanks for the help!
Kind regards,
Paul
____________________________
To err is human; to blame problems on external factors is even more so.
Paul
paul.pacini - Posts: 12
Re: Support for Phidgets 4-channel DAC?
I dont know if you have solved this problem, but the 4 channel DAC is listed under phidgets analog in flowstone. The full phidgets lineup is supported.
- machinist
