Crustcrawler AX-12A Smart Arm+USB2Dynamixel+flowbotic
Hi I am Adam..
I own 1 units crustcrawler Ax-12A arm robot + USB2Dynamixel + CM-700,
Alex Dirks CEO of Crustcrawler ask me to try the new flowbotic.. so I have download:
# Free trial flowstone V2
# Dynamixel Servo Test .fsm code
http://www.dsprobotics.com/support/viewtopic.php?f=52&t=360#wrap
# Flowbotics Studio V1.27 (code only) & V1.21(exe & code)
http://www.dsprobotics.com/support/viewtopic.php?f=71&t=416
To check the usb2dynamixel working, I connect all 7 motor to USB2Dynamixel and use dynamixal wizard software(roboplus). All the motor can move
First I try with Dynamixel_Servo.fsm but all dynamixel not moving. I dont know where to select COM port or baud rate setting..
Then I use Flowbotics Studio V1.27.. there is no EXE file, so I open the fsm file..
#No Arm found, I change to COM 3 but still no arm found.. the green indicator is not turn on..
Next I try Flowbotics Studio V1.21(code and EXE),
#still no arm found and no movement even after I change COM3 port..the green indicator is not turn on..
DId I miss any step? Could someone help me? thanks~
- adamsya
Re: Crustcrawler AX-12A Smart Arm+USB2Dynamixel+flowbotic
Quite a few steps..
There is a test example especially for the CrustCrawler Arm here: http://www.dsprobotics.com/support/viewtopic.php?f=53&t=352
Only Flowbotics Studio V1.27 supports the CrustCrawler Arm and in order to compile it you will need a full FlowStone Pro license or at least an 18 Month free Trial (that you get with the Arm + FlowStone bundle).
If it says no Arm files found it means that you haven't installed it correctly. In the download there are four separate Arm files that setup the arms, these files should be in the same folder as the EXE (or in the FlowStone install Folder). Without these it will never work.
I've tried it all here and it works perfectly.
- DSP
Crustcrawler AX 12A Smart ArmUSB2Dynamixelflowbotic
cool works great for me,Time lag, but that is to be expected, Good work.
byronPeary - Posts: 2
