deleted by uploader
deleted by uploader
deleted
tiffy - Posts: 400
Re: Multipurpose Push Button
tester did whole bunch of them.
But tester will not interfere here.
I'm glad that my little tools inspire others to do some great stuff.
hi
here is another way of doing the toggle action without the need for the counter!
Regards
Regards
- Jay
deleted by uploader
deleted
tiffy - Posts: 400
Here is another version of the Push Button - Multipurpose Toggle v1.0.2 with even less components.
Push Button - Multipurpose toggle v1.0.2.fsm- (12.84 KiB) Downloaded 1318 times
tiffy - Posts: 400
Did you noticed, how many (rather not used) elements and patterns are inside parts of that button?
oh nice! ive never seen the toggle done like that before
- Jay
deleted by uploader
deleted
tiffy - Posts: 400
you also can get rid of the counter in the style module and use the output bool signal instead of the mouse trigger.. and i think the area modules in fill and outline are also the same or, it also can be used in the interaction module so you can do it just once and use the area in those 3 modules?
inside this area modules there are also some FineW and FineH which are not in use...
and in the mouse module you dont need the mouseLup because this trigger comes from the dragxy anyway (use the mouse drag primitive here instead of the drag y to use the bool directly from the mouse drag prim)
the background image for the colorselection area is also not needed when you dont have some alpha there..
deleted by uploader
deleted
tiffy - Posts: 400
