Multiplex/Selector Quirks
• Page 2 of 2 • 1, 2
Re: Multiplex/Selector Quirks
Multiplexor is definetely wrong... actually 99% of all time multiplexors are used for view (because view operates backwards).
@Nubeat7: You can connect booleans directly into selectors, you don't need "Int select" for converting boolean to integer.
MyCo - Posts: 718
MyCo wrote:Multiplexor is definetely wrong... actually 99% of all time multiplexors are used for view (because view operates backwards).
This is one of those cases where what you see isn't what you get. I don't see how you wouldn't want to use multiplexes in lots of your projects, aside from the problem I identified.
- Perfect Human Interface
Thanks Nubeat7 very good work easily, i adapted it to my project and its work great
happy new year all!
- RZK
