Position Synced StepLFO
Re: PositionSyncedStepLFO - help?
Postby Nubeat7 » Sun Jan 12, 2014 4:41 pm
optimized the code to get rid of the modulo division, and further optimizing in assembly..
edit: check first file for latest version!
Postby Father » Mon Jan 13, 2014 12:15 pm
This one starts on load, not when 'is playing' so it's out of sync.
I also noticed the smooth knob doesn't work, It's not effecting the audio as it should. (in previous version too).
Father
Postby Nubeat7 » Mon Jan 13, 2014 8:57 pm
did you unwire the pseudo host inside the ppq sync module? there you need to connect the timesig from host and the host ppq primitive, i was using a pseudohost module for testing inside FS, forgot to unwire this :(
about the smooth, thanks! there was a mistake in the code of the ruby stepsequencer, thanks for figuring this out.
fixed both things and reuploaded the last version
Postby Father » Mon Jan 13, 2014 11:40 pm
Sorry my bad! I didn't really look, was kinda busy, I knew it's something like that, happens a lot. It's fixed now.
I think steps height needs a bit correction. Because in positive mode there is a bit extra at bottom of every step, or rather there isn't a fixed line there.
I just tried this for a quick fix. added a 0.1 to height.
#--------draw Bars------------------#
@steps.times do |id|
if @positive
y = @h - @h*@Values[id]+0.1
h = @h+0.1
Father
Re: Position Synced StepLFO
Postby Nubeat7 » Fri May 29, 2015 9:19 pm
updated to the latest version in the first post, including the fl studio ppq fix which was discussed here:
viewtopic.php?f=3&t=2732&hilit=ppq+synced&start=30
Postby Father » Fri May 29, 2015 9:28 pm
Do we have a solution to identify the DAW yet? Its really unprofessional to ask users to choose if they are using FL studio or not.
Father
Postby Nubeat7 » Fri May 29, 2015 9:35 pm
no, there is no solution...
Postby Nubeat7 » Fri May 29, 2015 9:40 pm
but i think 99% of FL user's don't use any other timings than 4/4.. :)
Postby Father » Fri May 29, 2015 9:44 pm
Nubeat7 wrote:no, there is no solution...
True but they should really consider it on the next update, among other useful vst functions that's been missing.
Father
Postby Perfect Human Interface » Mon Jun 01, 2015 12:12 am
If you are one the IL forums you should post there about it. While they certainly may not do it just because you asked for it, they do listen closely to customer suggestions and most of their updates are based on customer feedback.
