System Info From Win32API
Postby Drnkhobo » Thu Jan 23, 2014 9:24 am
Hey guys, Im trying to figure out this code I found which returns system info (OEM ID, ect).
Now I only want to get some piece of data which could be used to link a machine to a FS app.
Here's the C++ code:
include <windows.h>
#include <stdio.h>
#pragma comment(lib, "user32.lib")
void main()
   SYSTEM_INFO siSysInfo;
   // Copy the hardware information to the SYSTEM_INFO structure.
   GetSystemInfo(&siSysInfo);
   // Display the contents of the SYSTEM_INFO structure.
   printf("Hardware information: \n");
   printf("  OEM ID: %u\n", siSysInfo.dwOemId);
   printf("  Number of processors: %u\n",
      siSysInfo.dwNumberOfProcessors);
   printf("  Page size: %u\n", siSysInfo.dwPageSize);
   printf("  Processor type: %u\n", siSysInfo.dwProcessorType);
   printf("  Minimum application address: %lx\n",
      siSysInfo.lpMinimumApplicationAddress);
   printf("  Maximum application address: %lx\n",
      siSysInfo.lpMaximumApplicationAddress);
   printf("  Active processor mask: %u\n",
      siSysInfo.dwActiveProcessorMask);
http://msdn.microsoft.com/en-us/library/windows/desktop/ms724423%28v=vs.85%29.aspx
I would appreciate any help as I have no C++ modules installed in my brain so far. Some things concern me, like "#pragma comment(lib, "user32.lib")" . . .
And the simple GetSystemInfo(&siSysInfo);
But like I said, I have no idea what im doing here! Anyone understand this? :roll:
Thanks :lol:
Drnkhobo
Re: System Info From Win32API
Postby Tronic » Thu Jan 23, 2014 10:45 am
Tronic
Postby DjMmix » Thu Jan 23, 2014 7:09 pm
hello guys,
I coded a dll in C + + with the function that you cited in your post that operates under FS
for pragma (that am under visual or Codeblocks) it is now useless.
and this procedure "GetSystemInfo (& siSysInfo)" is used to insert data into siSysInfo for future use ;)
join if I post my example use this info :)
sysinfoforfs.zip
Project,DLL et FSM
(17.42 KiB) Downloaded 973 times
coded under codeblocks .
DjMmix
Postby trogluddite » Thu Jan 23, 2014 11:01 pm
Tronic, DjMmix - many thanks, this is just the kind of stuff I need to see to get my C++ good enough to do something useful!
Postby Tronic » Fri Jan 24, 2014 5:23 am
is always nice to be able to help.
I can add a tip about the creation and management of new windows or other interactions,
you should always create them in a new thread.
Tronic
Postby Drnkhobo » Fri Jan 24, 2014 8:52 am
:o
Hats off to you guys!
Damn!
Really nice work there DjMmix! :lol:
Drnkhobo
Postby RJHollins » Fri Jan 24, 2014 9:52 am
I opened the ZIP and saw several files in there ... What are we suppose to do with these files ? Does the DLL need to be dropped somewhere ?
I've not tried running the .fsm file until I was sure what to do.
Thanks for any clarification!
Postby DjMmix » Fri Jan 24, 2014 10:55 am
hello guys, thank you for the encouragement :)
@ RJHollins: in the zip there is the dll concern the FSM and the rest of the files are the files for the "code::blocks" with which I created the dll project, but if you codeblocks or visual studio you can viewed project written in C + + to see how I did it;)
DjMmix
