Flowstone 64 bit ? I need 64 bit version
I have a 64 bit PC now is it possible to use flowstone 64 bit now? or is there away i can use flowstone or synthmaker 32 bit on 64 bit pc?
- djbrynte
Re: Flowstone 64 bit ? I need 64 bit version
You don't need 64 bit plugins for a 64 bit PC. You only need 64 bit plugins if your DAW software is 64 bit, and even if it is you probably have a 32 bit wrapper that can load 32 bit plugins.
- Perfect Human Interface
yes thnx i solved it!
- djbrynte
