Mouse selection with picture
• Page 2 of 4 • 1, 2, 3, 4
Re: Mouse selection with picture
That is a cool technique billv.
Thanks for doing that ... I just learned something new!
nice one billv, but when resizing the bitmaps you always need to fit the móuse areas which is not needed when you use the bitmapareas for mouseareas, like this you just load ( or rezize ) a bitmap and you automaticly get the mousearea for it...
mousearea_bmpsize.fsm- (6.82 KiB) Downloaded 869 times
...and here a ruby approach for a picture array.
Edit: Sorry there was an little error in the first attempt. Upped a new version
- stw
Nubeat7 wrote: load ( or rezize ) a bitmap and you automaticly get the mousearea for it...
Yeh..much better...
Note in your example this dosn't work cause I've got the area floats dis-connected
in the bitmap loaders.
Here's a quick adjustment.
Also an option(via properties) to resize bitmaps to view area of module.
I did try some ruby approaches....but got stuck controlling the mouse areas.
Hello !
Thank you for your help guys !! It's perfect
If i use the first picture for the background and the second picture for to be in front all (button etc...)
It's difficult ?
It's difficult ?
- rustyou
oh yes i just used your example to show the mouse logic and because the pictures have same size i let like it was... (with your hack to get different picture size)billv wrote:Note in your example this dosn't work cause I've got the area floats dis-connected
It's possible to change the color of picture before of clicked ?
- rustyou
Yeh,bitmap colour changes can be made with the colour matrix prim.
Inside the bitmap, replace the 'draw prim' with the 'draw transform prim' and add
a 'redraw' prim. Then add colour matrix prim.
The tricky part is all the math needed, to change the hue, saturation and brightness.
This has all been done by someone back at SM, so it's real easy.
Hi !
Great thanks you,
And in the example joint, if i to want changed the color of guitar logo to white before click...?
Great thanks you,
test color buttoninvisible.fsm- (155.93 KiB) Downloaded 864 times
- rustyou
