Mouse selection with picture
Re: Mouse selection with picture
Postby RJHollins » Thu Feb 13, 2014 7:42 am
That is a cool technique billv.
Thanks for doing that ... I just learned something new!
8-)
Postby Nubeat7 » Thu Feb 13, 2014 9:49 am
nice one billv, but when resizing the bitmaps you always need to fit the móuse areas which is not needed when you use the bitmapareas for mouseareas, like this you just load ( or rezize ) a bitmap and you automaticly get the mousearea for it...
mousearea_bmpsize.fsm
(6.82 KiB) Downloaded 765 times
Postby stw » Thu Feb 13, 2014 10:47 am
...and here a ruby approach for a picture array.
Edit: Sorry there was an little error in the first attempt. Upped a new version
picarray.fsm
(105.66 KiB) Downloaded 805 times
stw
Postby Nubeat7 » Thu Feb 13, 2014 12:09 pm
really neat stw! :)
Postby billv » Thu Feb 13, 2014 3:59 pm
Nubeat7 wrote: load ( or rezize ) a bitmap and you automaticly get the mousearea for it...
Yeh..much better...
Note in your example this dosn't work cause I've got the area floats dis-connected
in the bitmap loaders.
Here's a quick adjustment.
Also an option(via properties) to resize bitmaps to view area of module.
mousearea_bmpsize-2.fsm
(4.98 KiB) Downloaded 791 times
I did try some ruby approaches....but got stuck controlling the mouse areas.
Postby rustyou » Thu Feb 13, 2014 6:01 pm
Hello !
Thank you for your help guys !! It's perfect :)
If i use the first picture for the background and the second picture for to be in front all (button etc...)
It's difficult ?
rustyou
Postby Nubeat7 » Thu Feb 13, 2014 6:46 pm
billv wrote:Note in your example this dosn't work cause I've got the area floats dis-connected
oh yes i just used your example to show the mouse logic and because the pictures have same size i let like it was... (with your hack to get different picture size)
Postby rustyou » Tue Feb 18, 2014 9:03 pm
It's possible to change the color of picture before of clicked ?
rustyou
Postby billv » Tue Feb 18, 2014 10:47 pm
Yeh,bitmap colour changes can be made with the colour matrix prim.
Inside the bitmap, replace the 'draw prim' with the 'draw transform prim' and add
a 'redraw' prim. Then add colour matrix prim.
The tricky part is all the math needed, to change the hue, saturation and brightness.
This has all been done by someone back at SM, so it's real easy.
Bitmap color change.fsm
(32.17 KiB) Downloaded 748 times
Postby rustyou » Tue Feb 18, 2014 11:29 pm
Hi !
Great thanks you,
And in the example joint, if i to want changed the color of guitar logo to white before click...?
test color buttoninvisible.fsm
(155.93 KiB) Downloaded 753 times
rustyou
