centimeter & meter per square values into float
Postby audiomafia » Sat Feb 15, 2014 8:07 am
How to define values for centimeter per square & meter per square values into float, my cm per square value is 0.001 I want to divide it with in value & take the logarithm and output the result into some table code but it is not working. Thanks
Problem: Too much noise & oscillator behaves very different, rather complete cycle it lasts half of 180 angle & complete -180.
I tired de/sub normal values remover but result is same... Any clue?
audiomafia
Re: centimeter & meter per square values into float
Postby Jay » Sat Feb 15, 2014 2:52 pm
well 1 meter squared is 1000cm. 1 x 100 x 100 so if you wanted the result to be 1 as in 1 meter squared then your defined value would be 0.0001
0.0001 x 100cm x 100cm = 1 sq meter
is that what you are after? or am i missunderstanding?
like this -
meters.fsm
(359 Bytes) Downloaded 887 times
regards
Jay
Postby Xtinct » Sat Feb 15, 2014 5:32 pm
Jay
No misunderstanding how can you understand a bot?
I think its managed to hack awan1980's account ( same was posted on SM ) as he usually makes more sense either that or arwan did you bring enough for everyone?
Xtinct
Postby Jay » Sat Feb 15, 2014 9:29 pm
oh lol, cheers for letting me know Xtinct!
they are getting really trixie these bots :lol:
best regards
Jay
Postby RJHollins » Sat Feb 15, 2014 10:01 pm
Some of us still appreciate the effort and post you made Jay ... Thanks!
8-)
