Can some one help me with AM mod? (SOLVED)
How do i make a simple AM mod. Or ring mod? Just a simple one. AM is more important.
Im after the one in 3xOsc.
Says Osc>3AM
For 3 oscilators.
OSC 3 Amplitude Modulation (OSC 3 > AM) - Switch on to use Oscillator 3 as an amplitude modulation of the other 2 oscillators.
AH sry i did find a old post fro mtrog showing this. Thnx anyway (SOLVED)
Says Osc>3AM
For 3 oscilators.
- djbrynte
Re: Can some one help me with AM mod? (SOLVED)
here is one!
turn the red knob to hear it working! you can modulate it with whatever you want! modulation range is 0-1
Regards
Regards
- Jay
Thnx alot jay i will check this. I wonder why do 3xosc dont have any knob for the AM? its just on off mode?
Realy strange
Realy strange
- djbrynte
No problem m8!
it is possibly being auto modulated by an adsr or lfo, or any other sources available on the synth! not sure! I take it you are talking about the little 3osc synth in FL studio?
not used it for a while, but i will take a look at it
- Jay
Just had a look it does have a knob for the AM mod called pw! it randomizes the phase on all 3 osc's
the am mod on the 3osc is using the 3rd osc to modulate the output of osc 1&2
- Jay
So how do i do this?
Its just to hook up one AM math and make so that am effect both osc 1 and 2?
- djbrynte
yeh m8 thats about it! and feed the output of osc3 into the mod input onthe am module!
now! the output signal of osc3 will need levered into the 0-1 range to work correctly i reckon!
i will have a play with it later and see if i can figure it out for ya
- Jay
