Mouse selection with picture
• Page 4 of 4 • 1, 2, 3, 4
Re: Mouse selection with picture
rustyou wrote:I want a box who this close with the right clik of the mouse and to can added a text en picture inside of the box.
here's a box you can close with a right click. picture and text has been added inside.
Yes, but i need open a windows too..
(without btn OK in the windows)
And the windows close when i clik in the same windows. (left clik)
- rustyou
you are asking for something that is not possible atm in FS
- Jay
In this exemple, it's possible to have a picture (guitar logo) always bring the front ?? (always visible)
test color buttoninvisible2.fsm- (162.8 KiB) Downloaded 919 times
- rustyou
yup you just needed to change the link order of the wireless V connector to make the logo the top layer!
- Jay
No because I need to have the switch button who disappear when i clik.
Look this exemple the switch button is not behind the msg TEST
test color buttoninvisible3.fsm- (162.8 KiB) Downloaded 957 times
- rustyou
well you want it like this then
the button needs to go in the same layer as the bitmap that you are switching to with your black and white button.
- Jay
Yes ok,
To summarize, i have put all my programme in the first image
. And it's ok
Thanks you,
Thanks you,
- rustyou
no problem m8!
it is a bit of a learing curve at first when you get into Flowstone but before long you will be churnning out good stuff!
Regards
Regards
- Jay
