Mouse selection with picture
Re: Mouse selection with picture
Postby billv » Fri Feb 21, 2014 2:23 am
rustyou wrote:I want a box who this close with the right clik of the mouse and to can added a text en picture inside of the box.
here's a box you can close with a right click. picture and text has been added inside.
Logo_1.fsm
(138.84 KiB) Downloaded 1021 times
Postby rustyou » Fri Feb 21, 2014 5:23 pm
Yes, but i need open a windows too..
(without btn OK in the windows)
And the windows close when i clik in the same windows. (left clik)
rustyou
Postby Jay » Fri Feb 21, 2014 9:16 pm
you are asking for something that is not possible atm in FS
Jay
Postby rustyou » Fri Feb 21, 2014 9:46 pm
Ok
rustyou
Postby rustyou » Sat Feb 22, 2014 6:59 pm
In this exemple, it's possible to have a picture (guitar logo) always bring the front ?? (always visible)
test color buttoninvisible2.fsm
(162.8 KiB) Downloaded 928 times
rustyou
Postby Jay » Sat Feb 22, 2014 7:20 pm
yup you just needed to change the link order of the wireless V connector to make the logo the top layer!
(158.24 KiB) Downloaded 1021 times
Jay
Postby rustyou » Sat Feb 22, 2014 7:27 pm
No because I need to have the switch button who disappear when i clik.
Look this exemple the switch button is not behind the msg TEST
test color buttoninvisible3.fsm
(162.8 KiB) Downloaded 968 times
rustyou
Postby Jay » Sun Feb 23, 2014 12:08 am
well you want it like this then
test color buttoninvisible2-2.fsm
(158.07 KiB) Downloaded 1017 times
the button needs to go in the same layer as the bitmap that you are switching to with your black and white button.
Jay
Postby rustyou » Sun Feb 23, 2014 3:34 pm
Yes ok,
To summarize, i have put all my programme in the first image :). And it's ok
Thanks you,
rustyou
Postby Jay » Sun Feb 23, 2014 7:44 pm
no problem m8!
it is a bit of a learing curve at first when you get into Flowstone but before long you will be churnning out good stuff! :D
Regards
Jay
