Any word on a 64 bit version ?
Re: Any word on a 64 bit version ?
MegaHurtz wrote:It evolved into a robotics platform....![]()
But all I can find is GMO stuff, have a link?
Search youtube for "Cliostudios Genera". Not much, but something.
- Tzarls
development is allready busy for a few years
AFAIK, the biggest time-eater challenge was implanting mac-format exporting capabilities into a windows soft, so you don't need mac for doing that. in point of fact, this soft will work with windows only although it will be able to export cross platform. i believe exporting-to android is not that far, as Delphy based programs already grant "all-in-one" solutions. That's a good sign.
how should that work?
That's probably will be the easier part, as SE already has an adopting feature in it for years. Jeff was afraid of opening this feature completely in order not to be exposed to claims, and kept it as testing tool. Now, as we can see , adopting feature is not that spooky so Jeff will need a little push from users to be completely convinced.
I don't belive you will be able to export a flowstone dll using synthedit
i already did it! and i can prove it to you. but there were few problems, most of them are related to the graphics and the GUI as FS is generating graphics differently, and this difference causing CPU+memory+composition issues.
other than that, the sound was just great, and so the midi respond (SE''s strength point).
kortezzzz - Posts: 763
Here is an image i received from Jeff. an SE made plugin using vanilla gui on mac
http://s25.postimg.org/xmcal2u4v/vanilla_gui.png
kortezzzz wrote:Here is an image i received from Jeff. an SE made plugin using vanilla gui on mac![]()
That image is of a Windows GUI...
- Tzarls
Yes, i know. this is only a demonstration of the gui it self so people can understand what we are talking about. maybe i should send him a request for a picture of a real SE plugin running on mac and see what's happening. i will update.
kortezzzz wrote:i already did it! and i can prove it to you. but there were few problems,
how did you do that?
Very easy. Synthedit loads any 3party plugin that has been sended to selected folder by the options. You open a new project, load that plugin, put it in a container and create inputs/outputs for it. Then you fix the gui's location on the panel and export to vst format.
By the way, another issue i'v fotgot to count is loading time in a daw. It takes about 5-20 seconds to load fs+se made plugin
And i have no idea why. This issue will have to be fixed as well, so synthedit will function just like savihost.
I cannot deal with these issues. Slow/CPU/Memory Ui..
For freewares ok, but not selling them. Stability?
Will be better for FS to export no gui elements maybe.
PM me if you are interested.
CoreStylerz - Posts: 327
The point is if jeff decides to open this feature, everything will be improved and fixed, just like in fs .
When im saying there are issues, i mean they come up using the se 1.2 alfa version.
Hope for his success.
hmm sounds like pretty crappy solution...
better hope for FS 64 support
