Rubygems
Re: Rubygems
Postby DSP » Wed Jan 11, 2012 10:13 pm
Wrapping up into a FlowStone Project:
require "Win32API"
def event i,v
   getForegroundWindow = Win32API.new('user32', 'GetForegroundWindow', 'V', 'L')
   window_handle = getForegroundWindow.Call()
   getWindowText = Win32API.new('user32', 'GetWindowText', 'LP', 'I')
   title_buffer = ' ' * 512
   getWindowText.Call(window_handle, title_buffer)
    output 0,title_buffer
As you say works without the buffer? Maybe it's a Ruby thing as you don't have to define the size of the variable?
Ruby Get Window Title.fsm
Show the Title of a Selected Window
(466 Bytes) Downloaded 1271 times
DSP
Re: Rubygems
Postby sal » Thu Jan 12, 2012 1:14 pm
thank you,
i did already try do change the PATH and my mistake was about my ruby version compiled with minigw, with the mswin version i can use some gems and i'm having problems with some other gems(the ones i would use) such as the sqlite3 and the mysql ones.
For example trying to require sqlite3 from irb it works, but inside flowstone ruby module it doesn't.
sal
