Generated EXE get to 100% CPU after close
Hello!
What could be done, if an exe does not close in background and if it just eats up 100% cpu on a single core after closing it?
EXE was in fullscreen and got exit by the primitive.
Regards
C.Hackl
Regards
C.Hackl
chackl - Posts: 233
Re: Generated EXE get to 100% CPU after close
I remember there was a discussion here on ruby and overload with amount of ruby modules. But if this is exe fullscreen only - I guess this isn't it.
Oha... there a realy LOADS of very BIG ruby modues inside
The fsm measures about 3MB, the uncompressed EXE about 10mb and there is about 90% ruby inside :/
An the Ruby code inside is timer-based so it is executed about 10 times each second. The Exe needs about 20% CPU on a 2,1 GHZ dual core here.
An no i checked it now - it is not a fullscreen issue.
Is taskkill the only way to get this for the moment?
chackl - Posts: 233
hard to know without more info.
I will say things at random:
You have open connections?
save some files when closing the app?
tried to stop the ruby garbage collect before closing the app?
- Tronic
Tronic wrote:hard to know without more info.
Everything is stopped before exit - the exit comes with a timer after stop after 500ms.
There are no files saved and i also tried to reset the ruby objects.
But it randomly does not exit
regards
chackl - Posts: 233
what you mean with
try to disable the ruby garbage collector with the ruby code command:
GC.disable
and also you can utilize the primitive
[ About to Close ]
to send the trig to the primitive
[ Exe Quit ]
when all is done before to quit.
GC.disable
[ About to Close ]
[ Exe Quit ]
- Tronic
